Head Gasket
Old Feb 12, 2012 | 02:37 PM
Brando5641's Avatar
Default Head Gasket
will these work on 2002 LM7?
http://api.viglink.com/api/click?for...13290788898105
everyone els wants this price for just one gasket but will they work on a lm7?
Old Feb 12, 2012 | 08:34 PM
chrisfrost's Avatar
Yes they will work but they will lower You're static compression ratio a little bit ,,,,,,,,maybe from 9.45/1 to 9.35/1 it's hard to say exactly without knowing the difference the head gasket bore is ,,,,,,,,,but they are thinner so should be higher a little bit ,,,,,,,maybe 9.60/1 or higher
Old Feb 13, 2012 | 05:22 PM
Brando5641's Avatar
im kinda lost... so am i loosing comp or gaining?
Old Feb 16, 2012 | 08:46 PM
Brando5641's Avatar
TTT
also if im loosing comp. will it mess with valve lash?
Can i just use ls1 mls instead?
