Help me spend $2000
Old Feb 12, 2012 | 08:52 PM
cory32690's Avatar
Default Help me spend $2000
I have a 01 formula a4 car it's a daily driven and I mean daily as in only car it has 162k on it and about 80k on trans 162k on rear end the car has full maintance on it early everytime runs just as good as when my dad got it with 10k
As for mods
4k stall,long tubes to ory with bullet dumped before axle all
rear suspension, lid,
I'm debating If I should do all new top end with mild head and cam setup or should I just start building a shortblock due to the high mileage to the car and Im going to keep adding mods to the car
Old Feb 13, 2012 | 09:13 AM
zracer323's Avatar
If you plan on keeping the car for awhile, I wouldn't drop a lot of money on a motor with that kind of milage.
Old Feb 13, 2012 | 09:24 AM
Rare96LT1Formula's Avatar
You could always cam it and still have some nice change left over for a 6.0L swap motor.
Old Feb 13, 2012 | 09:28 AM
cory32690's Avatar
I figure either way it goes I can spend 2k on forged h beams and wiseco piston with stock crank or 2k on a top end just scared to put a cam in it and the motor give out
Old Feb 13, 2012 | 11:10 AM
wildcamaro's Avatar
Throw an ls6 top end with a nice cam and you can always build a shortblock on the side and already have a topend to put on it...I priced out rebuilding a shortblock and with good brand name parts I came up with under $700 to rebuild (rings,bearing,lifters,chain,gaskets,bolts)
Old Feb 13, 2012 | 11:21 AM
BOBS99SS's Avatar
Captain Double Post
since i had higher miles on mine i just did a few mods, i did do a cam and a few other things, but once i get a few things done i will start building a block, it sucks to have a project car and not be able to drive it or have fun with it, im torn between a turbo 5.3 build , or just go with a 6.0 build. but i think it would be worth it to throw a cam in there, if these motors are taken care of well they will last for awhile,
Old Feb 13, 2012 | 11:24 AM
1nasty86's Avatar
Turd Gen Guy
Circle d 4k converter..700-900$
Pacetter 1 3/4 headers... 250-300$
Tsp y pipe and true duals?
Bmr torque arm to take it off the trans?
Eps/tsp camshaft 400$
Ls2 timing chain-50$
ls7 lifters-120$?
Tune?
Biggest gain is going to be from the camshaft... seen a h/c/i ls1 make 481 with 1 3/4 pacetter headers.
Old Feb 13, 2012 | 11:25 AM
1nasty86's Avatar
Turd Gen Guy
And pray for your trans and rearend
Old Feb 13, 2012 | 12:27 PM
K11PER's Avatar
his trans isn't that old I would think, as appose to the rear holding up.
Old Feb 13, 2012 | 12:43 PM
01SOMZ28's Avatar
I have a friend who sprays 150 continuously (trigger happy) through his LS1 which has 158k without a single problem. I've seen many many others do the same. I wouldn't hesitate to do H/C if i were you. If it runs perfect and everything checks out fine, i don't see the problem....miles are miles, yank yank.
Old Feb 13, 2012 | 12:51 PM
VandykeT/A's Avatar
If you want to cam swap I would definately pull the heads and swap lifters and get a new oil pump just for insurance.
Old Feb 13, 2012 | 12:55 PM
cory32690's Avatar
I think I'm gonna just build a forged short block ls1 specs stock crank callies rods and wiseco pistons stock crank..and sell my shortblock out of my car and sell it to cover a cam kit
Old Feb 13, 2012 | 08:36 PM
cory32690's Avatar
Has anyone ever got a short block from mabbco
Old Feb 13, 2012 | 11:04 PM
VandykeT/A's Avatar
Never heard of them. You could probably build the one in your car for a little over 1k. It'll just be down for a while. Maybe find a low mileage 6.0 from a junkyard.
Old Feb 14, 2012 | 06:27 AM
cory32690's Avatar
Mabbco is a company that rebuilds factory shortblocks
They sell 6.0 full rebuild with a 90 day warranty for $1299
Old Feb 14, 2012 | 03:24 PM
cory32690's Avatar
Anyone heard of mabbco enterprise
Old Feb 14, 2012 | 03:29 PM
custm2500's Avatar
Ph.D. in HUBRIS
The best way for you to spend $2000 is to paypal it to me. I will tell you your car is much faster and change your timeslips with a pen. Then we are both happy!
