Will a oil free cam rust inside?
Old Feb 12, 2012 | 11:40 PM
VandykeT/A's Avatar
Default Will a oil free cam rust inside?
I brought my Torquer 2 inside from my building to make sure it wasn't rusted up and when I wiped everything off of it I got to thinking willl it rust now? Also the only thing oil based I have right now is gear oil. Would it hurt to put that on it just to protect it from rust.
Old Feb 13, 2012 | 02:20 AM
01ssreda4's Avatar
Cover it with gear oil and wrap it up. Before you put it in the motor wipe it all back off.
Old Feb 13, 2012 | 09:44 AM
bronx_peanut's Avatar
Spray it with wd 40 and you will be good to go.
Old Feb 13, 2012 | 09:58 AM
SweetS10V8's Avatar
Itll rust thats for sure. i use wd40 and wrap it in a cam bag.
Old Feb 13, 2012 | 10:31 AM
VandykeT/A's Avatar
I couldn't get to any wd 40 last night so i covered it in gear oil and put it in a all ready oiled plastic cam bag that it came in. Thanks
Old Feb 13, 2012 | 04:01 PM
01ssreda4's Avatar
That'll work perfect. I do my cylinder walls like this when the heads are off for an extended amount of time. Works like a charm.
Old Feb 13, 2012 | 04:40 PM
_GTO_'s Avatar
Why not an engine oil ?
Old Feb 13, 2012 | 05:26 PM
01ssreda4's Avatar
Gear oil is thicker and it comes in a handy squirt-able container. Plus I always have some laying around.
Old Feb 13, 2012 | 05:30 PM
farmington's Avatar
And it smells so, so good. Mmmmmmm
Old Feb 13, 2012 | 06:22 PM
VandykeT/A's Avatar
Also the 241s I plan to use have been sitting in the building for quite awhile and I got one out and looked at it. It doesn't have rust anywhere but then again its aluminum lol. Is there anything that could have happened to them from sitting about a year in a dry but not climate controlled building? Also would an oil pump be damaged from sitting?
