compression test results, dry and wet
dry 205,210,205,205 driver side
wet 220,225,220,220 passenger
wet 210,230,225,215 driver side
Engine is using almost 1 qrt of oil in just 300 miles. No smoke, good mpg highway and runs strong. No leaks either. Only 90k miles stock engine.
Been seeing alot with the newer DOD/AFM trucks
Kerosene or trannyfluid can help but you need to know what you are doing otherwise you can cause damage. The big thing is to not let it run at all with either in the engine.
