Not your regular LOW oil pressure thread
Old Feb 18, 2012 | 08:16 PM
chopperman69's Avatar
Sounds like a cracked block to me. Think about it. Oil pressure is normal when cold. When it warms up, the crack expands and you loose oil pressure.
Saw this on a Pontiac once. Chased the problem for months...
Old Feb 18, 2012 | 09:20 PM
fastazzls1's Avatar
yea but op is there any leaks at all
and also i would not suspect the block that would be the very last thing to rule out due to it being the most costly
Old Feb 18, 2012 | 09:56 PM
vladsvt's Avatar
No leaks, car is dry. Cracked block sounds like a possibility I suppose but I am mroe sure its the bearings
Old Feb 18, 2012 | 10:15 PM
This one didn't leak either. Cracked inside through one of the oil galleys.
