HELP!! TR cam stamp - is it right?
Old Mar 20, 2004 | 06:14 PM
chief455's Avatar
Question HELP!! TR cam stamp - is it right?
I bought a TR224/112/.563 cam used. It's mint but the markings don't make sense.
On one end of the cam hand etched is "T5873"
and under that stamped ""2870 A"
Please look at the attached pic.
Is this right?
Old Mar 20, 2004 | 06:25 PM
Tripp's Avatar
i have v1468 and 2370c etched on mine. i am still waiting to find out if mine is the right cam.
Old Mar 20, 2004 | 07:45 PM
Jason99T/A's Avatar
I can shift faster than you.
I'll check into both of these Monday. I didn't have time to check today for yours, Andrew.
Jason
Old Mar 20, 2004 | 08:54 PM
chief455's Avatar
Jason
Thanks , I appreciate any help
Old Mar 20, 2004 | 10:07 PM
Z28Venom's Avatar
I've been wondering the same thing about the cam that I bought.
I've seen pictures of Thunderracing Cams, and some of the actually have TR230... blah blah blah.. whatever the first number is.
I was a bit worried about the one that I bought because it didn't have that.
It's almost like yours.. It has a stamped number and then an etched number.
The cam should be a TR230/224 .575/.563 LSA 111...
Old Mar 20, 2004 | 11:37 PM
Jason99T/A's Avatar
Depending on when the TR cam was purchased, it may have different "styles" of engraving on the backside of the cam. The earlier versions had just an engraved serial # (ex. UF5466, B4533,etc.) and another stamped core number. The later versions had the same engravings as the earlier versions, but an engraved part # was included (ex. TR224-12, TR224-14,etc.).
Jason
Old Mar 20, 2004 | 11:47 PM
Z28Venom's Avatar
Thanks for the explanation....
Old Mar 20, 2004 | 11:53 PM
Jason99T/A's Avatar
No problem! If you anyone purchases a TR cam used and wished to verify it is indeed a TR grind, just email me the serial # on the backside and I'll get look it up in the Cam Pro Plus computer at work.
Old Mar 21, 2004 | 01:14 AM
Tripp's Avatar
thanks Jason, we really appericiate it.
Old Mar 21, 2004 | 04:29 AM
chief455's Avatar
Jason
that is great information, thank you!
I wonder though..wouldn't the stamped core number be like say, the advertised duration/h for hydrualic or something? Or just a plain old "2870 A" means the cam started from a "2870 A" piece of stock before being ground to specs identified by the hand engraved serial number?
Either way - you'll be able to hook us up Monday from the computer?
That's AWESOME man - really nice of you to offer
Old Mar 22, 2004 | 01:26 AM
Jason99T/A's Avatar
Correct, the "2870A" is just the core # and has nothing to do with the actual specs of the cam.
I'll get the info for everyone Monday.
Old Mar 22, 2004 | 06:24 PM
chief455's Avatar
Any luck getting those numbers checked out?
I'm pretty curious and wanted to keep this thread up top
thanks
Old Mar 22, 2004 | 08:18 PM
Jason99T/A's Avatar
OK, here is the info everyone was looking for:
OB8417: originally doctored on 4/15/02, TR224/112, 224.3/224.1 .564/.563 111.6 lsa
OB9824: orginally doctored on 5/6/02, TR224/114, 224.0/224.1 .562/.562 113.5 lsa
T5873: orginally doctored on 10/19/02, TR224/112, 224.3/224.1 .563/.563 111.8 lsa
UD1078: originally doctored on 3/6/02, TR230/111, 230.5/224.6 .575/.561 111.0 lsa
V1468: not found in the computer; there was a V1486, so I don't know if you mixed up the last two digits.
There were the cam IDs that people posted here or that sent me their info via a PM. If anyone needs another one checked, please let me know.
Jason
Old Mar 22, 2004 | 10:23 PM
Tripp's Avatar
do u know what the specs where for the V1486?
Old Mar 22, 2004 | 10:26 PM
Jason99T/A's Avatar
No, I can't recall off-hand. I'll check tomorrow for you.
Old Mar 22, 2004 | 10:33 PM
Tripp's Avatar
thanks, ill double check later when i get home tonight. i think somebody said that might be a comp cam number, i hope not. if those are the right numbers and it just isnt a TR cam where could i get the specs checked out? is there a machine that can get the specs for me?
Thanks
Tripp
Old Mar 22, 2004 | 10:37 PM
Jason99T/A's Avatar
Tripp, you can send the cam to Thunder and we can doctor it on our cam doctor. This will let you know exactly what the specs are. We charge $25.00 plus shipping.
Old Mar 22, 2004 | 11:18 PM
IrateTA's Avatar
Mine was pretty straight forward...
Old Mar 22, 2004 | 11:57 PM
Tripp's Avatar
i just got home and double checked it. i had it written right everywhere but here.
V 1486
Old Mar 23, 2004 | 12:17 AM
chief455's Avatar
Jason
you the man!!!
these are on a +4 intake centerline, correct?
