HELP!! TR cam stamp - is it right?
Old Mar 23, 2004 | 12:23 AM
chief455's Avatar
Originally Posted by IrateTA
Mine was pretty straight forward...
yes - but until now I would have guessed the hand etchings as fakes!
All my Comp, Crane, Ultradyne etc. cams from older Pontiacs had stampings of either a grind number to call in or the basic lobe/lca numbers with an H or S for hydrualic or solid lifters at the end...
Old Mar 23, 2004 | 12:36 AM
Jason99T/A's Avatar
I can shift faster than you.
Yes, all of these cams have 4 degrees of advance ground in.
Old Mar 23, 2004 | 05:37 PM
Jason99T/A's Avatar
More cam info:
UD3442: originally doctored on 4/16/03; TR224/112, 224.2/224.0 .562/.562 111.7 lsa
V1486: originally doctored on 1/8/02; TR224/112, 223.9/223.6 .563/.563 111.8 lsa
Old Mar 23, 2004 | 07:18 PM
greekss's Avatar
where do i check to see if i truly got a B1 cam, i bought used with 1000k mikes and no cam card. How do solidify that this is a B1 cam and not anything bigger
Old Mar 23, 2004 | 09:33 PM
chief455's Avatar
get the numbers from the end of the cam and contact the manufacturer.
All our cams in this post are TR so Jason at TR could get the info...
Old Mar 25, 2004 | 11:20 PM
Randy WS6's Avatar
I have a Thunder Racing and lost cam card. my cam has engraved -V0579 and stamped-2870C could you help me to
Old Mar 26, 2004 | 02:31 AM
Wildman's Avatar
Sent you an email Jason.
Thanks,
Paul.
Old Mar 28, 2004 | 04:49 AM
VXCHEV's Avatar
Cool
Originally Posted by Jason99T/A
No problem! If you anyone purchases a TR cam used and wished to verify it is indeed a TR grind, just email me the serial # on the backside and I'll get look it up in the Cam Pro Plus computer at work.
Jason,
Do you have the specs for y4191
Cheers
Les
Old Mar 29, 2004 | 05:05 PM
Jason99T/A's Avatar
More cam info:
X2774: originally doctored 5/24/02; TR230/111, 230.8/224.2 .576/.563 110.5*
V0579: originally doctored 12/4/01; TR224/112, 224.4/224.2 .562/.562 111.7*
Y4191: not found in the computer
T9862: not found in the computer
Old Mar 31, 2004 | 06:45 AM
1BDWS6's Avatar
Jason....you got mail. Thanks in advance!
Old Mar 31, 2004 | 02:58 PM
Ohio Bird of Prey's Avatar
Default Thanks in advance Jason.
Jason
I too have a TR224 I'll be installing when my heads are completed.
It is a low mileage item with p/n R7972 on the end.
I'd like to know for sure what I got.
Old Mar 31, 2004 | 10:43 PM
  #32
Jason99T/A's Avatar
Z7206: originally doctored 6/13/03; TR230/227 112, 231.4/227.9 .575/.569 111.9 lsa
R7972: originally doctored 6/26/01; TR224/112, 223.6/223.8 .557/.557 111.7 lsa
Old Apr 1, 2004 | 10:00 AM
  #33
1BDWS6's Avatar
Really appreciate it!
Old Apr 7, 2004 | 09:10 AM
  #34
VXCHEV's Avatar
Question
Found the specs on the cam grind above
Can you help me out with another it has the letter R (is this
for reverse split) above the last grind number Y8879
Other numbers are 3728R/3110S HR 110.
I'm told it's a Thunder racing spec cam
Thanks in advance
Les
