New timing set, crank gear wont go on all the way
Just finishing up a cam swap, and I replaced my timing set with a rollmaster single roller. I got the gears lined up perfect, and I have the new cam gear on and torqued down. I put the crank gear on and it looks like its not on all the way. The cam gear appears to be sitting farther back than the crank gear is, and the keyway on the crank isnt level with the gear, there's probably 1/16th to 1/32nd of an inch gap there. What to do?
