help with oil pump issue!
Old Mar 21, 2004 | 03:11 PM
BRIAN98Z28's Avatar
Default help with oil pump issue!
Im pretty sure the reason i popped the motor in my 98 was due to a failed oil pump....damn 98s. Well im putting a new motor in, also from a wrecked 98 and i want to be DAMN SURE this doesnt happen again. What are you guys' reccomendations as far as which pump is the best. Ive seen thunders modified LS6 pump, also seen a ported and blueprinted SLP pump. Which one should I get?
Brian
Old Mar 21, 2004 | 04:44 PM
Ferocity02's Avatar
I got the TSP ported LS6 pump. It's a great piece and isn't too expensive
Old Mar 21, 2004 | 05:39 PM
14u2nv's Avatar
I personally would go with the Thunder Racing unit over the SLP.
Old Mar 21, 2004 | 07:37 PM
1QUIKWS6's Avatar
Active Streak: 30 Days
I went with the TS&P Ported LS6 Pump & then just recently sent it out to AP Engineering for their coating process - Oil Shedding Coating on the outside + teflon coating on the gears & the inside (you can only send out a pump for coating that has not been installed yet)
-Jay-
Old Mar 21, 2004 | 11:54 PM
Zero2Sixty's Avatar
Thunder ported LS6 pump here.
Old Mar 22, 2004 | 12:06 AM
Speedfreaks101's Avatar
-Jay-
Why??
