Stock pushrods?
Old Feb 23, 2012 | 07:59 PM
custm2500's Avatar
Ph.D. in HUBRIS
Default Stock pushrods?
I am getting push rod measurments of 7.385-7.4. From what I can tell my stock Lq4 pushrods are 7.4. Will they be just fine or should I upgrade to a aftermarket 7.4?
I hear everyone talking about "hardened" pushrods but are the stock ones hardened and just as strong?
Sorry if this is a dumb question but I couldn't find an answer.
Old Feb 23, 2012 | 08:39 PM
jsteele90's Avatar
Stock is 7.4. I use tx speed pushrods
Old Feb 23, 2012 | 08:40 PM
jsteele90's Avatar
Stock ones are weak sauce
Old Feb 24, 2012 | 06:48 AM
custm2500's Avatar
Ph.D. in HUBRIS
That seems to be the case but I didn't want to assume. Trying to figure if aftermarket rushrods were more for addressing length issues or strength.
Old Feb 24, 2012 | 08:05 AM
01ssreda4's Avatar
Stock pushrods suck.
Old Feb 24, 2012 | 08:48 AM
MikeFSKSpeed's Avatar
I have the Comps in stock. 7.4" Long - $95 + shipping.
Mike
Old Feb 24, 2012 | 10:12 AM
mpatton's Avatar
Comp is the way to go
Old Feb 24, 2012 | 10:52 AM
vettenuts's Avatar
How did you measure, and did you measure gauge length or overall length? It is different.
Pushrod strength covers different things. For straight strength, area is the driver. For bending, outside and inside diameter along with length governs. Since length is the same in your case, then diameters are the driver. Hardening won't change flex or stiffness, only diameter changes will do this. Hardened are good for guide plates, which aren't required for the LS1 unless you go to stud mounted rockers. Bottom line, get the correct length and maximize the outside diameter.
Here's more information if you are interested: Link
