LS1 Yella Terra 1.8's with Zo6 Cam?? QUESTION
LS1 with Camshaft Specs: Duration: 204/218 Lift: .550/.550 LSA: 117
I NEED new rocker arms...going with Yella Terra's, Possibly 1.8s....
Will i run into an Issue Running a larger Ratio Rocker Arm with this cam?
I'm undergoing a total over haul
So far i have:
Lunati Dual Valve Springs
Zo6 cam Duration: 204/218 Lift: .550/.550 LSA: 117
New Stock LS1 Oil Pump
New Double SLP roller Timing chain
New Lifters
New Bearings (cam, Main, Rod)
LS2 Water pump (this motor is going in a 2000 S10 I need the short pulley)
H3 Oil Pan
MLS Head Gaskets
All new Fel-pro gaskets
All parts are GM Perfromance parts except a few
and I'm waiting to get the rockers to measure for pushrod length.
So far i have:
New Lifters
H3 Oil Pan
MLS Head Gaskets
