PTV milled 243,MS4
Old Feb 25, 2012 | 10:32 PM
ice95z's Avatar
Default PTV milled 243,MS4
Stock 243 heads milled.007. Ms4 cam installed straight up. Dual prc springs, 7.4 rods, ls7 lifters. stock bottom end.
Checked ptv with clay and no head gasket. Came out to .045 clearance. Does this sound right? And can I use the stock lifters to check ptv or will they collapse too far? Thanks in advance
Brian
Old Feb 25, 2012 | 11:44 PM
black00ssFL's Avatar
They will collapse, giving a false reading. Need to use a solid lifter. I'm willing to be you'll touch the piston with no headgasket.
