Best Cam Only (most power and driveability) for a DD
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Looking for a bumpstick to throw in my new motor and I am having trouble deciding which one will give me the most power while retaining driveability. I intend to use this cam at the track say once every two months and for the street to eat mustangs and such. so mainly a street cam with good torque and a nice long powerband, sayy 2-6, the highest i want to rev is probably 6500
full bolt ons and cutout, m6, good clutch and shifter.
i think thats enough explanations
Thanks!!
Thanks!!
I agree with cranny, look at the 228...first can I went with was a 224 and after a week I wanted a bigger cam. Since you going to be running on the street is stay at or just under .600" lift and to get your power coming in earlier maybe a 110-112 lsa
there is no "best" cam
if you really want one tailored to your setup have Pat G spec you a custom cam.
I had a 228R in my h/c/stall/intake LS6 trans am. it was great, but I would have went bigger next go around. but be weary, high lift eats springs every 20-30k miles and $350 for springs every 30k adds up!
ya ran the streetsweeper, for the last 2 years. That cam is bad ***, and ran great you can find some info on that. I made 425whp 395wtq, and went a few 10.66s at 128's cam only with that. And the car was heavier then it is now, with all stock front stuff just single adjustable shocks really.
The new one I have makes more power, and runs the same really. You have to flycutt for it, the streetsweeoer you don't. But looking for MOST power I'd do it.
http://www.neweraperformanceparts.co...mart&Itemid=54
Others have tried to copy it, but they just can't perform the same as this FTI profile due to it's proprietary lobes. Expect gains of 65+ rwhp from this cam, specs are roughly 236/240 .630/.615 111 LSA. Driveability when properly calibrated is better than what you would expect with a cam this size.
