What head gaskets do u recommend
Old Feb 27, 2012 | 12:08 AM
juanioz28's Avatar
Default What head gaskets do u recommend
I have a 5.7 ls1 but im putting a cam and some milled 243's which head gasket do i need to use? And whats the part number for them
Old Feb 27, 2012 | 12:20 AM
crazyelf's Avatar
GM MLS gaskets part #12498544 this part number is for a pair.
Old Feb 27, 2012 | 12:32 PM
juanioz28's Avatar
Thanks for the help i will buy them right thank again
Old Feb 27, 2012 | 12:47 PM
2QUIK4U's Avatar
It depends on what size cam. If you want more compression you could go with a Cometic gasket in .040.
Old Feb 27, 2012 | 01:08 PM
MikeFSKSpeed's Avatar
What he said^ I Keep the Cometics in stock, always have GREAT luck with them
Old Feb 27, 2012 | 01:37 PM
01ssreda4's Avatar
I'm running the Fel-Pro MLS gaskets currently and have been pleased with them.
Old Feb 27, 2012 | 01:52 PM
CamaroSS27's Avatar
I use these.
Old Mar 5, 2012 | 09:42 PM
juanioz28's Avatar
I have already milled heads
Old Mar 5, 2012 | 09:45 PM
Burken01's Avatar
milled to what cc? what compression will you be at?
GM mls gaskets will work fine, or cometic .040 would as well... and with a better quench!
but either will work for you, I actually bought both when I did my H/C swap because I couldn't make up my mind..
Old Mar 9, 2012 | 02:51 PM
zstripper2k's Avatar
What CR will you be at with stock 243s and cometic .040s?
Old Mar 9, 2012 | 07:36 PM
purple98haz28's Avatar
"What CR will you be at with stock 243s and cometic .040s?"
i would like to know this as well
Old Mar 10, 2012 | 01:51 PM
01ssreda4's Avatar
Old Mar 10, 2012 | 03:50 PM
Burken01's Avatar
and ended going with neither, going turbo instead... go figure..
Old Mar 10, 2012 | 04:57 PM
MFCptnMorgan's Avatar
Anyone know this answer?
Old Mar 10, 2012 | 10:58 PM
Burken01's Avatar
no not yet
