rocker arms and set up
what is the stock rocker arm ratio for a 97 z28 camaro. im trying to layout a motor and i cant seem to fint out if there 1.5 or 1.6 could some one shed some light on this for me below is the planned set up im thinking on using in a 69 chevelle ( t56 and 4.11 ) if you could give me some feed back i would realy like to hear what you have to say
Planned Set up
Doing some head work ( port matching ) reworking the chip, full exhuast, and doing the comp cam
Part Number 07-502-8
Engine 1993-1996 Chevrolet
350ci,
LT1 & LT4,
8cyl.
Grind Number LT1 XR269HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.495 0.503
Duration At 0.006 Tappet Lift 269 276
Valve Timing At 0.006
Open Close
Intake 26 62
Exhaust 74 22
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.33 0.335
Lobe Separation 112
Planned Set up
350ci,
LT1 & LT4,
8cyl.
Description
Intake Exhaust
Open Close
Intake 26 62
Exhaust 74 22
Intake Exhaust
Lobe Separation 112
