Woke up and engine knocking, What is it?
Old Feb 29, 2012 | 06:17 PM
Tubba's Avatar
Default Woke up and engine knocking, What is it?
when I started 01 Trans am this morning I heard a light knocking in the idle but then it went away after it warmed up(10 mins), should I be worried?
Old Feb 29, 2012 | 06:25 PM
sepsis's Avatar
Piston slap. It is common with LS1's apparently.
I'll take the car off your hands for $2k....rid you of the problem.
Old Feb 29, 2012 | 06:36 PM
Thule's Avatar
probably piston slap. really common with those motors. nothing to worry about
but if id gets worse and continues after the motor gets warm then it most likely spun a bearing
Old Feb 29, 2012 | 08:43 PM
Tubba's Avatar
Im at 76,xxx mi. How do i go on fixing this problem? And How much is this gonna cost me to fix
Old Feb 29, 2012 | 08:48 PM
redsilv's Avatar
if your neighbor keeps putting saw dust in your
engine id bet it will get expensive real quick LOL
naw im thinking piston slap too
ive got an engine that had piston slap and got 248,000 miles and still going
change your oil maybe that will help the lifter ticking
nothing you can really do other than a rebuild to fix piston slap
