Hank the Crank LS1 cranks....
http://www.hankthecrank.com/LS1CRANK2.htm
Phillip
If you ever build with a Racemaster, just remember that the number 8 piston(I think it was at least) has to be clearanced to clear the reluctor. It was necessary for Diamond pistons at least.
BTW, I recently saw the remains of a twin-turbo LS6 that wasn't prepared correctly. The block had twisted about a 1/4". The only thing re-usable will be the HTC crank and the cam, after some cleanup and polishing.
http://www.callies.com/catalog/cranks/magnumPlus.html
The difference is basically the amount of machining that has been done to the crank. We planned on doing a lot to the crank, so I bought the Racemaster.
There are a lot of good cranks out there. HTC and Callies are just two of them.
Yup. I'm alive. Just got really busy.
