Should I do heads or a cam?
This is a tough question...But if heads are not in the future, then cam for sure! BUT if you want heads in the future, the cam will be a waste because it probably be not the best for the new heads. I vote both at the same time.
EDIT....After looking at the kit, doesnt that seem a little pricey for what you get? Correct me I'm wrong here but you can get the cam/springs/push rods for $600-700, that means the 5.3 heads are $1100 with no springs? The thats alot of $$ for stock heads. What kind of horsepower is there to gain for the investment?
I would consider finding #799 or #243 heads and run them cleaned up or as it and a cam. That would keep you at $1000 if you got a good set of heads at $350-$500
http://www.texas-speed.com/p-1159-pr...m-package.aspx
My advice is to save up for when you can buy the heads and cam together so they are matched. Or pick out your heads, and have a custom cam ground around the heads and other mods. You will thank yourself later on when your running circles around people that took the other route.
and yea install yourself. It'll save so much money then you'll have more to play with.
