Should I do heads or a cam?
Old Mar 10, 2012 | 10:02 AM
  #41
ta-stanger's Avatar
I would also just buy the heads or send off a set of 243 to AI and save my money for the cam and do it all at once! Those AI 243's are the ****!! That is a great Cam choice also!
Old Mar 10, 2012 | 10:22 AM
  #42
BrntWS6's Avatar
Don't forget to budget for a new clutch, my LS6 clutch with 17k miles on it didn't even make it through the second pull on the dyno.
Old Mar 10, 2012 | 12:17 PM
  #43
NemeSS's Avatar
Cam and tune.
  #44
Tainted's Avatar
your stock 10 bolt isnt enough with stock power. 10 bolt FTL
Old Mar 10, 2012 | 05:33 PM
  #45
redtan's Avatar
Your not gunna get full potential from the cam on stock heads either.
Of course not, unless you specifically get a cam that's made for the stock heads and nothing more.
But the whole point is which will be more beneficial and get more out of the other stock part. Depending on the cam, you can get like 80% of it's potential with stock heads. But for heads, you would probably get like 40% of their potential with the stock cam.
Obviously it would be best to get a cam matched perfectly to the new heads, but not everyone has the cash to do that and apparently he can only do one. He could more power out of a new cam with stock heads than stock cam with AFR heads.
Old Mar 11, 2012 | 12:48 AM
  #46
garygnu's Avatar
for under $1800 you can do the TSP cam/head pkg ,including the swap kit.
Old Mar 11, 2012 | 01:00 AM
  #47
camfreak's Avatar
or he could do the ls6 cam and get 317 mil the .40 40 over they would be like ls6 heads and they are in every junkard
Old Mar 11, 2012 | 01:01 AM
  #48
camfreak's Avatar
it cost only $347 for the head work
Old Mar 11, 2012 | 12:40 PM
  #49
AMS13's Avatar
I just finished installing a monster stage 2 in the car, now i just need to install my suspension and I can figure out which cam and heads to go with. The TSP kit looks great but I am now having a struggle between the Torquer v3 and the Street sweeper HT, doing springs every 20k does not sound like something I would like to do.
Old Mar 24, 2012 | 06:53 PM
  #50
INFRONT86's Avatar
Do the cam. If you order up the cam, I'll order up a set of sets.
