01 ls1 best oil help
Old Mar 9, 2012 | 09:06 PM
jerrito98ss's Avatar
Default 01 ls1 best oil help
Hey guys i have a 01ss and i need to do a tune up tommorrow what oil should i use? Weight and filter ect....i live in the desert at about 3600ft elevation
Old Mar 9, 2012 | 09:11 PM
Darkman's Avatar
Pennzoil Platinum 5W-30, with a Wix filter.
Old Mar 9, 2012 | 09:14 PM
badazz81z28's Avatar
Royal purple!
Honestly.....oil is oil. just don't buy dollar general oil
Old Mar 9, 2012 | 09:25 PM
2002ss335's Avatar
Take a look at this thread. Quaker State for free.
https://ls1tech.com/forums/general-m...-oil-free.html
Todd
Old Mar 9, 2012 | 09:37 PM
Paul Bell's Avatar
That's MISTER MODERATOR
Store bought brands:
Any top shelf synthetic oil, 0W-30, 5W-30. Mobil One extended oil filter.
I use Castrol German (GC) 0W-30 and a Fleetguard oil filter.
For filters, stay away from Fram, STP, Quaker State, any store brand filter and Fram.
Old Mar 9, 2012 | 10:33 PM
Thanks guys
Old Dec 27, 2012 | 02:14 PM
needtransam's Avatar
Jerry what did you end up putting?
Old Dec 27, 2012 | 02:37 PM
Ferocity02's Avatar
Use whatever oil you want, but stay away from the cheapo stuff like Napa and O'reilly. Just keep it changed often, refer to the manual for the correct weight.
Old Dec 27, 2012 | 02:47 PM
badassracing's Avatar
I dont use it but there's nothing wrong with napa oil. Its valvoline in a napa bottle.
Old Dec 27, 2012 | 02:55 PM
02_Orange_D1SC's Avatar
formerly twolow02fransen (2014-1-2)
yuppers most people dont know that only reason i do is i used to work there
Old Dec 27, 2012 | 03:03 PM
Ferocity02's Avatar
Good to know! What about Peak oil? My local Napa has it for pretty cheap.
Old Dec 27, 2012 | 09:13 PM
therabidweasel's Avatar
http://www.bobistheoilguy.com/
^^^^^^^^lots of good info here. For cheap stuff Ive been using Rotella T6. Good stuff is Amsoil.
Old Dec 27, 2012 | 10:02 PM
Ferocity02's Avatar
I tried T6 but it caused some very loud tapping in the valvetrain. 10W-30 made it much quieter. Going to try 5W-30 next.
Old Dec 27, 2012 | 10:44 PM
RezinTexas's Avatar
"best oil" question typically nets nothing but subjective answers. but you don't really know anything about your oil until you have a sample analyzed from your application.
Old Dec 27, 2012 | 10:50 PM
FAD2BLK93's Avatar
I use Royal Purple 20-50 with a K&N filter. Or a WIX filter sometimes...stay away from Fram. I believe i saw a test on them where the paper material inside really really slows down the oil, possible starvation. Someone know about this? I also heard in the old days Pennzoil used perafin wax in there oil. I have seen some old T Birds oil pans that were completely sealed in the stuff. WOW!!! i dont know if it is in their products now? But i will NEVER use it EVER!!
Old Dec 27, 2012 | 11:11 PM
ejbta2's Avatar
my new motor instructions required me to use Valvolive 20/50 mineral oil so I am using Valvoline 20/50 VR1, that's what I will continue using. As for the filter was told to use AC Delco. I have found a lot of drag racers with 800+ hp at my local track use the oil.
Old Dec 27, 2012 | 11:30 PM
Sorry if hijacking OP, but what lifters/lobes are you running? I am running the Johnsons in my sig, LSL lobes...has never tapped with amsoil, napa, rotella, penzoil platinum, or M1. The guys at Johnson did say that high end lifters don't like real heavy oil because the clearances are so tight.
Old Dec 28, 2012 | 07:43 AM
Valvoline VR1 is a very good oil but it has high zinc levels for flat tappet engines. Dont use it if you are running cats.
Old Dec 28, 2012 | 08:52 AM
wildcamaro's Avatar
For what it's worth 5-30 and 10-30 are the EXACT same oil once at operating temp, the first number (5w,10w) is the oil viscosity when the engine is cold, use 10w in the summer and 5w in the winter...Mobil 1 here, but any quality synthetic is good
Old Dec 28, 2012 | 05:14 PM
Ferocity02's Avatar
That might be true, but what is considered "operating temp"? If the engine may be running cool enough such that there is a difference. I have looked for charts/graphs of viscosity versus of oil weight and cant find any for 5W-30 versus 10W-30.
