Cam install
Old Mar 12, 2012 | 11:36 PM
SmallBlock 383's Avatar
Default Cam install
I put in my Comp 228/230 cam in my ls1 last week.. Cleaned engine real good before I did it, and also lubed cam real good but I sort of a hard time getting it to go in, I had to spin the cam a few times and use a good bit of force to get it in there, I even took it out again to make sure everything was clean and all and reinstalled it but im just wondering if this sounds bad to anybody thats put in a cam before.
Old Mar 12, 2012 | 11:50 PM
Guitar's Avatar
From what I've read and seen, that seems pretty normal.
Old Mar 13, 2012 | 12:04 AM
Ok, I was just makin sure cause on some videos ive see they were spinning the cam over by hand pretty easy so i was just wondering
Old Mar 13, 2012 | 12:30 AM
Redbull87's Avatar
Just need a steady hand,go slow sliding it in and spin it a few times.Shouldnt need much force.
Old Mar 13, 2012 | 03:35 PM
gMAG's Avatar
As Redbull said, it shouldn't take any 'force'.
It should gently slide right in while spinning the cam.
Is it possible that your lifters were sitting low in their bores, obstructing the cam?
Old Mar 14, 2012 | 07:35 PM
I don't know. I had the motor upside down while i was installing it because i'm putting all new bearings and everything in it. They may have been
