Old May 19, 2016, 07:12 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Engine Guides
Print Wikipost
cylinder head flatness tollerance?
Old Mar 13, 2012 | 03:28 PM
3rdCoastPowerSports's Avatar
Default cylinder head flatness tollerance?
anyone know the tolerances for flatness/ evenness of a cylinder head using an MLS gasket? Off the top of my head i think the absolute max is .003" but i could be wrong. any one know?
Old Mar 13, 2012 | 03:46 PM
just got off the phone with felpro tech line. if anyone wanted to know the answer to the question its is as follows (per felpro tech line rep):
Front--------------------Rear
allowed .001" per combustion chamber, so 4 chambers per head= .004" max tollerance
Up
| max tolerance is .001"
down
these are the absolute max tolerances. from experience i have run a .003" front to back tolerance (head was a little warped) and the head sealed up fine, not sure i would ever go past that though
Old Mar 13, 2012 | 07:20 PM
ssnovaturbo's Avatar
If boosted, better make sure both head and deck surfaces are straight as an arrow....anything over 10lbs and it becomes a must
Old Jan 13, 2016 | 04:56 PM
Jarren_b's Avatar
Sorry to bump an old thread but was anyone able to confirm that the max tolerance for an LS2 block and head using an MLS gasket?
Im trying to measure mine
Old Jan 14, 2016 | 07:37 AM
vettenuts's Avatar
Blocks are basically the same so the same numbers should apply. As I recall, there is a second number side to side but I can't remember the value. Thought it was 0.001" but am not positive about that.
Old Jan 14, 2016 | 09:35 AM
RonSSNova's Avatar
Surface finish is also important. Modern mls gaskets need a smooth finish.
I found that out the hard way after having my heads cut in old school machinery.
I think .002" or less for heads. I was at .003" and had issues.
Old Jan 14, 2016 | 10:24 AM
Jarren_b's Avatar
GM says the max is .004.
How do you get a good finish? someone suggested I use 400 grit paper and WD40. is this correct?
