ready to check pushrod length and ptv...
I read a thread about the mantons and i think im gonna use them. Peace of mind kinda thing.
So this also might be a dumb question but will the comp trunion upgrade affect my measurements i got for the push rods? I have the kit im just a bit hesetant about intalling them since my rockers are in good shape.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
Hey guys not to thread hijack but I am in the process of measuring for pushrods and ptv also. So I can have a clear understanding I am suppose to have proper pushrod length before measuring ptv? Also how can I turn a roller lifter to a solid lifter for checking these things?
So let me ask this:
I need to check PTV on my current set up that I have been running the last 2 years with no issue (2004 LS1/228R cam/7.400 PR/stock 241 heads, stock short block). I am ordering some AI High Compression 241's and Phil wants a current PTV measurement just to see if we have any room for milling and what not.
I ordered some checker springs and a pushrod length checking tool. I should recieve them in a couple days.
CAN I just swap in the checker springs and use my currently installed pushrods to measure PTV with a dial indicator? What I have researched is since the checker springs exert little force on the lifter it will not cause the lifter plunger to depress, which if it did compress would giving me a false reading.
I would rather do it this way before I make a damn mess removing everything.
Thanks guys
Thanks guys
