Rwhp????
Old Mar 25, 2012 | 02:25 AM
Sammy01ta's Avatar
Ok so after talking with tsp I'm not gonna do rear end cuz it's mainly a street car and they said get rid of shorties with the pacesetter long tubes and catted y and monster stage 2 full kit with slave and 410's with a 233/239 .595/.603 112 lsa...conservative est they said was 415 rwhp...what do y'all think and do I need new timing chain or oil pump. It's an 01 ws6 with 60,000 miles
Old Mar 25, 2012 | 02:33 AM
gs462's Avatar
I would NEVER replace a cam and put used timing set on it, makes NO sense to me, Also while you have it apart get the ported oil pump from TSP also for safety sake.
Old Mar 25, 2012 | 04:02 AM
baxsom's Avatar
new timing chain is like 40 bucks. the tsp pump is kinda overkill when you can get melling or GMPP for less than 100 bucks
Old Mar 25, 2012 | 12:19 PM
Sammy01ta's Avatar
Do I just replace the chain with stock new one or whole timing set
Old Mar 26, 2012 | 07:34 AM
Sammy01ta's Avatar
And if whole timing set witch one is a direct replacement
Old Mar 26, 2012 | 08:14 AM
njmaster's Avatar
You could do an LS2 timing chain set. This is what a ton of people do when swapping cams. Or you could go with a double roller timing set.
Old Mar 26, 2012 | 12:13 PM
Sammy01ta's Avatar
LS2 timing chain set it is then thanks...anyone know where the best place to get a melling oil pump
Old Mar 26, 2012 | 02:17 PM
njmaster's Avatar
The best price i can find for the Melling 10296 oil pump is $125 at Jegs? Someone else may know where to get one cheaper.
Old Mar 26, 2012 | 02:30 PM
Drokkers's Avatar
Originally Posted by njmaster
you could do an ls2 timing chain set. This is what a ton of people do when swapping cams. Or you could go with a double roller timing set.
x2........
Old Mar 26, 2012 | 04:18 PM
BrntWS6's Avatar
You want the high pressure pump (10295) not high volume. Sent you a PM with a link for under $100.
Also, you won't have any problem using the stock cam gear, just replace the chain. Providing visually it looks ok of course.
Old Mar 27, 2012 | 07:49 AM
Sammy01ta's Avatar
Thanks a ton guys!
