What valve spring to run? Under a budget
I agree though; If it's a track # you're after, go titanium. I believe Lunati sells a titanium retainer to go with the kit, but it's of course extra $
weeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeee
WEEEEEee is joking, somone needs to weight stuff yourself its NOT what you read on the internet.
This site is full of stupid things, that keep getting brought upsteel and Ti weights.... just Google that, Wikki or some science website ???
better wear? when are retainers wearing out????
https://ls1tech.com/forums/dynamomet...nly-setup.html
Holy ****. That's QUITE a difference!
I'm going to agree with Red on this though and say it prob won't matter at all on a street car. Hell, I think you're on your second set anyways..... If there were issues I'm sure you would have already told us.
I sent an email to Lunati yesterday to try and find out of they even had a Ti retainer that can be bought to "upgrade" this kit. They don't at this time, as per Shane Pochon @ Lunati.
I need 155# on the seat though for my cam Ed spec'd for me, so it's between these Lunati's, or PRC .675's. Hell, for 150 bucks more I get the Ti retainers. Paired with 11/32's Manton pushrods I'd imagine I'd have a pretty damned stable valve train.
I'm curious though as to the longevity of PRC's .675's. We all know the Lunati's last at least 25k.
There 20 other things but weight.... I should say mass. Lower is better on top of the valve, but other things matter too. Are the seat and open spring pressure, And the range you install (height) of them within its coil bind. Rocker ratio, rocker nose mass. Lifter lash, push rod deflection (it could help), valve weight, intake pressure (boost), exhaust pressure, heat, oil.
You could do everything "right" buy the latest and greats new spring kit, with Ti retainers. Just toss the kit dry on your heads, like everyone dose. With no idea how close they are to coil bind. Or different from valve to valve in the machining differences. And dyno or test drive right after. And have them fail out just be down 25-40 pounds on the seat after 25K miles.
Or on the same engine (cam) have the same springs with heavier retainers. But setup right, so the spring can work better and easier. And It might only loose 10pounds after 25K miles
