cam swap..which one..specs?
I would also recommend lifters, pushrods, oil pump, and a timing chain while you are in there.
http://www.engpwrsys.com/index.php?a...od&productId=6
Futral has the F4 (226/226), and the F5 (224/228), either one can be had with a 112 or 114lsa. Both will have 2* overlap with a 112lsa, and -2* overlap with a 114lsa.
The cam sound will be noticeable, just not as much as the EPS TT3, and these cams will also be very streatable.
http://www.futralmotorsports.com/fms...asp?pf=3&pg=29
Ron
I did the cam, srpings and pushrods only. Left the oil pump and timing chain and valve seals alone. So far so good oil pressure has never been, nor is it now and issue on my car. Timing chain and sprokets looked new when I had the car apart. IMHO if your car is low miles, not messing with the oil pump and valve seals is a viable option. Lots of guys screw the oil pump o ring up and end up getting real low or none at all oil pressure, and there were a few stories around of guys changing the seals and having oil seep by issues and smoking and oil consumtion. I felt it better just to leave them alone. The springs Igot, PAC 1218's are a strait swap, use factory retainers/seats and locks. Tools I highly recomend, Crane Cams LS spring compressor and Hawk harmonic balancer instalation tool. Both were well worth their premium in price.
Oh and I went with a 110 LSA, the cam sounds way bigger than it really is. Gives you that lope of a Tsunami or a MS4 with the more usable powerband starting around 1400-6K
http://www.youtube.com/watch?v=r435s...1&feature=plcp
