loud tick after cam swap
Old 03-23-2012, 02:34 PM
KevinR's Avatar
Originally Posted by 99z28ls
i know they are not the best quality since I had to use a phone but you can still kinda hear it.
Honestly, I don't hear what you're describing.
Old 03-23-2012, 03:27 PM
02anti_vnm's Avatar
Yeah i cant hear it either but i had a buddy with a ls6 swaped monte carlo it collapsed a ls7 lifter that had about 1500 miles on it. It wasnt excessively loud. It'd start out real quiet almost like the injector tick that the ls1s have naturally then would get noticably louder as the car warmed up. But it was never loud enough to hear from more than 10-15 ft away. can you notice exactly what side its coming from?
Old 03-23-2012, 03:50 PM
99z28ls's Avatar
ill try to find my camera but its louder on the passenger side.
Old 03-23-2012, 03:53 PM
02anti_vnm's Avatar
hate to say it but id pull that head and check the lifters.
hell go ahead and buy you a set of ls7 lifters, pull your heads get a 5 angle valve job and mill about .020 off, then slap it all back together...
thats what id do
Old 03-23-2012, 04:27 PM
99z28ls's Avatar
thats what id do
that is the plan right now if i have to pull the heads. im gonna put ls2 trays ls7 lifter and i have a set of 5.3 heads im gonna have a buddy who works at machine shop do some minor porting and put my 2.00 valves in.
Old 03-23-2012, 04:34 PM
02anti_vnm's Avatar
sounds like a solid plan man!
A couple other things id suggest is a set of arp head bolts or studs because you will have to buy new head bolts and the arps i dont think are much more but they are reusable in the future where as the stockers arent and you have to change them every time.
Old 03-23-2012, 11:18 PM
99z28ls's Avatar
I just dont want to go through all the work and money and still have the same problem as now.
Old 03-24-2012, 11:44 PM
99z28ls's Avatar
Old 03-25-2012, 01:01 PM
smokeshow72's Avatar
Man, I hear a little something in the video but it sounds more like an exhaust leak than a dead lifter; my laptop speaker may be to blame for that, though.
C
Old 03-25-2012, 08:44 PM
99z28ls's Avatar
im pretty sure its not an exhuast leak since I didnt touch the exhaust and it didnt do it before.
Old 03-25-2012, 09:20 PM
A.R. Shale Targa's Avatar
I thought that cam needed 7.425" pushrods for unmilled heads
Old 03-25-2012, 09:25 PM
  #32
blackbird0230's Avatar
just went through the same problem. Order a comp cams pushrod length checker, The 6.800-7.800 will work. Check your pushrod length just as you normally would. Check multiple cylinders and both intake and exhaust sides. determine your length and don't let anyone tell you youre effing wrong. I had the 7.400 pushrods and ended up needing 7.500 but the people I talked to said I was wrong and that there was no possible way I got that length on stock heads,or my lifters were bad. The whole run around checking every possible variable. I was right. ordered 7.500 and it worked. Maybe you had the same problem I did. definitely check pushrods.
oh and my car is all stock heads/ intake/ lifters/ rockers
Old 03-26-2012, 09:06 PM
  #33
zlthomps's Avatar
Yeah man, I would definitely agree than a cam over .600 lift like yours on a stock cylinder head (unmilled) needs 7.425" pushrods. $120 for some pushrods to me, is a no brainer for not having to pull the heads off again. Good luck, man.
Quick Reply: loud tick after cam swap
