Rings..Hone block??
Old Mar 23, 2012 | 04:26 PM
SmallBlock 383's Avatar
Default Rings..Hone block??
Im putting new rings in my ls1 with stock pistons do i need to hone the block or will I be fine by just putting in the new rings
Old Mar 23, 2012 | 05:04 PM
mark21742's Avatar
If you don't see any real signs of wear just run a hone in it real quick to get a good pattern back in the bore so your new rings seal up good
Old Mar 23, 2012 | 05:52 PM
batboy's Avatar
Yes, you need to break the glaze and get a good cross-hatch pattern in order to get new rings to seat.
Old Mar 23, 2012 | 07:51 PM
hcb1700's Avatar
I'd do it if I were you. As mentioned above, that will help with ring seal.
Old Mar 24, 2012 | 12:15 AM
bww3588's Avatar
It will help, but if there is no obvious damage, the rings will seal fine. Rings these days are designed to seat and seal on existing cylinder surfaces.
But a light hone with a ball hone will not hurt. Just make sure to gap the rings accordingly.
Old Mar 24, 2012 | 06:20 AM
Thumper28's Avatar
My local shop hones for $7 per cylinder. So for about $50 it probably worth it. Then while your there you can have them clean the block which will clean out all the oil passages and make it nice and pretty.
Old Mar 24, 2012 | 09:15 AM
RonSSNova's Avatar
I agree. If you hone, use a fine grit. Like 380 or so.
Ron
Old Mar 24, 2012 | 09:44 PM
wildcamaro's Avatar
The best "do it yourself" method is to use a flex-hone....it is a dingleberry looking device that does a real good job, I consulted with tony mamo about grit and he recommended 400 so that's what I got...the hone is like $50 on eBay
Old Mar 24, 2012 | 09:51 PM
bww3588's Avatar
380 or 400 grit will do. I like The 380 ish better as a rougher surface will force the rings to seat quicker leaving less time for the cylinders to wash down.
Just make sure you get the cross hatch angles right, about a 45 degree angle on the cross hatch is nominal.
Once it's running, get it up in the revs to about 2k for a few minutes to keep it from loading up with fuel. Let it hang for about 5 minutes and take it out and flog it.
Old Mar 25, 2012 | 11:53 AM
A.R. Shale Targa's Avatar
In addition to the hone/crosshatch....this stuff really works
http://www.jegs.com/p/Total-Seal/Tot...50299/10002/-1
