over rev
Old Mar 24, 2004 | 08:09 PM
ducati916's Avatar
Default over rev
I think i overreved the engine the other day. What happens to it? What should i look for? If no problems are detectable can there still be something wrong, thats not noticeable?
Old Mar 24, 2004 | 08:29 PM
Fast SS on TNT's Avatar
If you have no obvious valvetrain noise, or ticking you should be fine. You have a built in rev limiter that protects the motor from over revving. About the only thing you can do from over revving is float a valve. Unless you have programmed your rpm limiter in your pcm to a very high redline.
I have over reved my engine before, and all it does is set off a temporary SES code which quickly goes away.
No ticks, no grinding, no problems. Now stop worrying so much!!
Old Mar 24, 2004 | 09:23 PM
JoSeY's Avatar
ticking....pushrods bent.....9 out of 10 times a stock LS1 or mildly modded LS1 engine is over-reved pushrods are bent...other than that the stock bottom end can take 7500 rpm every now and then w/out too much worry....
if ur car is down on power check the PR's 1st...they're easy....after that...it's usually a sign u floated a valved and had a piston smack it..
Old Mar 24, 2004 | 09:47 PM
ducati916's Avatar
if i floated a valve how can you tell if you did. What would happen if the bottom end didnt handle it? the top end?
Old Mar 24, 2004 | 10:23 PM
DenzSS's Avatar
The rev limiter cannot protect you from a mechanical over-rev such as the 1-2-3-2 common shifting screw up.
Old Mar 24, 2004 | 11:03 PM
UGotBeaT's Avatar
mine hit the rev limiter a couple times cause my throttle cable got stock and i had one broken pushrod...took off the heads cause the knock was loud and found out my piston was caved into my cylinder wall......
