LQ4 + 706 heads
Old Apr 4, 2012 | 03:58 PM
widopn's Avatar
Default LQ4 + 706 heads
I was wanting some opinions on my set up. I have an lq4 with a tsp228r with the stock 317 heads on it. Iv managed a 12.33 @109 with it in my s10. I feel like there is alot more to be gained. I know the low compression sure isn't helping anything so ive been pondering on pulling the 317's and getting them milled or doin some port work on a set of 706 heads I have and sticking them on. I know more compression is a big + but I'm running a 4000 stall, so bottom end isn't much of a concern. I just wanted to get some opinions about the heads and see what is the better route. Any help is greatly appreciated.
Old Apr 5, 2012 | 05:14 AM
widopn's Avatar
Anybody ?
Old Apr 5, 2012 | 09:46 PM
Fosnot's Avatar
something you might want to note is the flow numbers on a stock 4.8L head, that an the smaller intake valve (1.89 vs 2.00"). If you port them out and blend the bowl a bit and smooth out the casting you could probably outflow the 243 heads (LS6) despite the smaller valve
Old Apr 6, 2012 | 12:24 PM
widopn's Avatar
Thanks, what I had in mind was taking the swirl ramp out and blending the bowls on the 706's. I had also considered putting the 2.00 intake valves from the 317s in them. Do you think that would be better suited for a n/a lq4 vs milling the 317s ?
Old May 22, 2012 | 09:27 PM
widopn's Avatar
bump... anybody else have any input on this ? any help is greatly appreciated..
Old May 22, 2012 | 09:34 PM
garygnu's Avatar
I feel it would be cheaper to mill and port the 317 heads.practice porting on the 706 heads.
