whats it worth? - built short block/spun bearing
Found a local guy selling a ls long block with a spun bearing.
Mods that i know of:
Dart pro 1 heads
Comp cam .600 lift range
Arp rod bolts with stock bottom end
Not sure what else but im sure there is a few other small things.
Whats it worth?
Dart pro 1 heads
Whats it worth?
count out the arp rod bolts if it spun a rod bearing, if its a main they "may" be ok. figure used prices on everything minus the bottom end (if completely stock).probably with the heads in the $1500 range depending on the quantity of good parts
I spun a bearing in mine and in the end needed 1 rod, crank turned 10/10, and aligned bored after I lost oil pressure.....if that gives you an idea on labor to get it right again.
