Want to compare notes on oil
Old Apr 6, 2012 | 04:33 PM
Whiteaw57's Avatar
Default Want to compare notes on oil
Just want to run some temps pressures and RPMs by you guys and get some opinions. I don't think I have a problem just want to see where I compare.
Stock longblock other than cam with 108k miles
Using castrol edge 10w-30
Cold Idle:
Oil temp guage pegged on 100*
38 psi
Hot idle:
Oil temp at 180*
32 psi
Hot Cruising:
Oil temp at 180*
38-40 psi @1900 rpm
Max Temp Idle:
Oil temp at 225*
30 psi
Max temp Cruising:
Oil temp at 225*
34-36 psi @1900 rpm
PSI jumps up to 65-70 under full throttle/6000 rpm so I know im safe. It is the stock oil pump so Im thinking this seems fairly normal. Just wondered what everyone else was seeing. I would like so soon get a new pump for it. Thanks for any experience
Old Apr 6, 2012 | 09:21 PM
99fbodyTA's Avatar
i have the same issue. my pressure even drops to around 25 sometimes the longer i sit and idle
Old Apr 7, 2012 | 01:18 AM
Whiteaw57's Avatar
I don't really see it as a problem. Thats plenty of pressure. Just wanted to be sure the guys on stock oil systems saw the same results. Thanks for the reply!
