Barbell question
Old Apr 6, 2012 | 11:22 PM
gMAG's Avatar
Default Barbell question
I am installing a new barbell.
The old barbell pulled right out. I noticed that the old barbell o-ring was showing/not pushed in to the block.
Should the o-ring be pushed inside the block when installed, so that it isn't visible? If so, should the o-ring be lubed, first?
Old Apr 6, 2012 | 11:36 PM
gectek's Avatar
Lube first. Push the bell in until you feel it seat. The back should be nearly flush with the block.
Old Apr 7, 2012 | 07:47 AM
gMAG's Avatar
Thanks.
I'm now wondering if the old barbell had been pushed backwards, leading to a lack of oil pressure. As noted, the o-ring was showing.
The new barbell & o-ring has a deeper rear (outside edge 3/16"), compared to the old (1/16"). Could this be a design change?
Once the barbell gets pushed rearward, wouldn't the cover have to be removed to push it back in?
I guess I'm not understanding the mechanics of it.
Old Apr 7, 2012 | 08:08 AM
cwalsh's Avatar
The rear plate does hold it in place, but if the O-ring fails it can affect oil pressure. Kind of unlikely for it to fail though.
