big cube engine
Old Apr 7, 2012 | 08:20 PM
97badass's Avatar
Default big cube engine
Is it possible to build a 427 or larger out of a stock iron 6.0? Or do I need a 6.2 block for that?
Old Apr 7, 2012 | 08:44 PM
MonmouthCtyLS7's Avatar
https://ls1tech.com/forums/generatio...-0l-block.html
Old Apr 7, 2012 | 11:16 PM
batboy's Avatar
I've heard that some 6.0 iron blocks can be bored to LS3 size (4.065" or 4.070"), but you need a good block with no core shift and should sonic test it before hand. Then use a 4.10" stroke crank (426/427 CID depending on bore size) or 4.125" (429 CID). But, strokes over 4.00" pull the piston too far out of the bore on the down stroke which wears the piston skirt faster and also the piston ring landings are thinner which sacrifice strength. Another down size is that a lot of clearancing is required for the longer stroke cranks.
It's better to stay with the tried and true 408 CID (4.030" bore and 4.00" stroke). But, you can get a rotating assembly that uses the 4.030" bore and a 4.10" stroke (418 CID) or 4.125" stroke (421 CID). Again, I personally would not go more than a 4.00" stroke on a 6.0 block. The LSX iron block is a different story though, they can handle bigger bores and longer strokes.
Old Apr 7, 2012 | 11:45 PM
97badass's Avatar
Thank you batboy. That's what I was wanting to know, I tried searching but nothing useful came up. If I was going with the lsx block I would go with a 454 but I can't afford the lsx block plus the machine work plus the internals...
Old Apr 8, 2012 | 12:00 AM
gectek's Avatar
If you go that big it would also have to be hard blocked and normally no boost or nitrous should be used. A tall fill is in order def!
Schwanke sells the 427 iron 6.0L shortblocks, but I believe they use a long *** stroke and a quick search on their site shows they no longer offer them, I am sure its for a really good reason also.
PS with a proper setup, a 408 can do some KILLER things. They can use a wider variety of head designs and make them work, like most of the larger runner cathedral heads, LS3 heads and some others.
Old Apr 8, 2012 | 12:24 AM
97badass's Avatar
Right now I have a freshened lq4 stock bottom end and ls3 topend with a tsp cam
Old Apr 8, 2012 | 12:53 AM
gectek's Avatar
Get a good rotating assy for that 6 liter for a 408, have the topend addressed with a good cnc job and a proper cam and you will be happier in no time.
Old Apr 8, 2012 | 06:19 AM
97badass's Avatar
I need to get this one running first, I'm pushrods away from having it put together, then a stall and headers.
Old Apr 8, 2012 | 09:07 AM
mark21742's Avatar
I run and love my 408....the real secret is you can run a cam in an engine this big that has a huge amount of duration, so big that you can throw the normal max scr factors out the window and still run on pump gas.....I'm running 12.5:1 static compression on 92/93 pump gas with full timing and 0 knock (a safe 8.22:1 dcr) 255/263 comp cam. I have my idle set at 850/900 and it pulls hard ad hell up to my 8,000 rpm fuel cut.
Old Apr 8, 2012 | 12:54 PM
97badass's Avatar
Nice! I just have the 229/236 .623/.617 112lsa
