BT Racing Springs
The springs are made in Brazil, but so are the Comp, Manley, Lunati, Patriot, etc, etc.
The quality of my kits is comparable to the Comp and Manley Nextek, but my overhead is far lower so I can sell for less.
Brian is always helpful and willing to go the extra mile to ensure his customers are taken care of and happy also. Hard to find that now a days when you're the "little guy" on the receiving end.
This is the easiest most simplest way to look at Brian's springs selection and what will work best for you.
If you're build is utilizing stock rockers, then use his Platinum springs.
If you're build is utilizing aftermarket roller rockers, then use his Max Pressure springs.
The Extreme springs work just as well as the platinum springs do, but Brian had told me he was phasing them out a while back. He may or may not be still doing this, but at least that is what was told to me.
The Platinum springs are only 400 lbs @ .660" lift and work great with stock rockers. Too much open pressure when using stock rockers can damage valve tips long term.
The Max Pressure springs have 450 lbs @ .650" lift and work great with roller rockers. The increased moment of inertia of aftermarket roller rockers requires increased open spring pressure to avoid loft over the nose. The Max Pressure springs when used with roller rockers could use more than standard 5/16" .080" pushrods.
I hope this helps.
I hope this helps.
Brian has always recommended the use of at least 11/32 .110" wall push rods or 3/8" .080" wall push rods with after market rockers and over 425-430lbs. of open pressure.
I hope this helps.
Once again, thank you for your quick response to my earlier question.
