Internal LsX "Experts"
Old Apr 17, 2012 | 02:02 PM
SSCamaro99_3's Avatar
Originally Posted by SmallBlock 383
Well I didn't have it together when i first post the thread but after sitting around a while and comparing pistons&rods I said screw it..I'll just put it together to see what happens..I don't see it being as big of a deal as everyone saying it is because its stock rods and pistons, Im not going to be beating on it too bad plus im tired off waiting on my Slow *** machine shop to do everything, I bought the car with a knocking motor and haven't even had a chance to drive it.. its been sitting in the yard for 3 months and I'm Sick, Im ready to fire her up so I went ahead and Put it together Last weekend.
Guess i'll have to learn the hard way but you never learn until you try !
You basically got a "No" 4 minutes after posting. Best of luck.
Old Apr 17, 2012 | 03:16 PM
SmallBlock 383's Avatar
After i post the thread 3 times with no answer, now everybody wants to ******* comment after i put the **** together. Just my luck!
Old Apr 17, 2012 | 05:28 PM
el33tprodigy's Avatar
If i was you I'd pull it all back apart and save yourself the 2500 or so it will cost to fix it all while you still can!
Old Apr 18, 2012 | 05:32 AM
I didn't have it in the car yet so i went ahead and pulled it apart,
Its my fault for rushing to put it back together so I cant be mad at you guys for trying to help me
Old Apr 18, 2012 | 07:57 AM
Smart move man... Its easy to pull them apart but putting them together balanced and the right way is where the time needs to be really taken..My buddy and I can have an engine out the top of a camaro in probably an hour and a half. But when we put them back in we take out time becuase of the fact we want everything done right.
Old Apr 18, 2012 | 04:19 PM
I understand that. Do you think i can reuse the main bolts or do they need to be replaced also?
Old Apr 18, 2012 | 04:56 PM
bww3588's Avatar
Tty...replace them.
Old Apr 18, 2012 | 05:20 PM
Originally Posted by bww3588
Tty...replace them.
gotcha
Old Apr 18, 2012 | 05:23 PM
If you can't replace them and they are arp they should be safe to reuse but i would inspect them first .....
Old Apr 20, 2012 | 11:06 AM
3rdCoastPowerSports's Avatar
they are not tty and can be reused as long as they have not had that many cycles on them and they are in good shape. with that said, i like to replace them but i have reused main bolts several times with no adverse side effects
Old Apr 25, 2012 | 12:16 AM
01cherryreds10's Avatar
I was kinda hoping you would have run it the way you had it just to see what would "actually" happen.
Good choice though
