Help! Hydro locked engine!?
Old Apr 13, 2012 | 06:10 PM
0verkill's Avatar
Default Help! Hydro locked engine!?
I was out driving the other night and was going WOT and felt a vibration in the motor, then I saw a bunch of smoke behind me and the engine shut off completely. I tried to restart the car as I was still driving on the road and it didn't do anything at all. I checked the radiator and it lost a bunch of coolant and the oil dipstick shows 2 quarts over full (it's not over full of oil). It was smoking from the intake and radiator. So I believe it's hydro locked. There's no leaks anywhere.
Any ides on what broke?
Old Apr 13, 2012 | 06:21 PM
TransamGCS's Avatar
sounds like you blew a head gasket,
Old Apr 13, 2012 | 06:22 PM
trans_am7935's Avatar
head gasket
Old Apr 13, 2012 | 06:59 PM
redsilv's Avatar
x3 head gasket
Old Apr 13, 2012 | 07:59 PM
tsquared38016's Avatar
If it is still locked, take out the plugs. You will probably drain some water out of at least one cylinder
Old Apr 13, 2012 | 08:01 PM
badazz81z28's Avatar
What the heck is hydro locked???
BOBS99SS's Avatar
Captain Double Post
x4 headgasket
Old Apr 13, 2012 | 08:03 PM
BOBS99SS's Avatar
Captain Double Post
hydro locked is when your running hard and drink to much gatorade, to much and it will seize up lol, something like that anyway, sorry its been a long day
Old Apr 13, 2012 | 08:05 PM
01BlueSS1995's Avatar
hydrolock is where water gets in combustion chambers, since water is near impossible to compress, bad things normally happen, enough water and blocks have a tendency to go kaboom!
Old Apr 13, 2012 | 08:28 PM
Seems like a term I have only heard here. I don't see why that couldnt happen to a trad SBC
Old Apr 13, 2012 | 09:37 PM
88blackiroc's Avatar
I want a video of when you pull a spark plug! Haha
Seriously though im gonna go x2123 on head gasket.
Old Apr 13, 2012 | 09:41 PM
I_Need_Land's Avatar
think how a 4 stroke engine works.
intake, compression, power, exhaust strokes...
water, non compressible...
water goes in the intake, or in this case a popped head gasket leaks water into a cylinder, when the piston comes up to the compression stroke, well.. 7 other cylinders are trying to force that water to compress - which isnt gonna happen, so naturally the rod tries to leave planet earth with a quickness.
as for the op, good luck, motor vibration? ill bet you've got one hell of a bent rod.
Old Apr 13, 2012 | 09:42 PM
heres a hydrolocked amg 6.3 engine i tore down last summer due to a failed injector sticking open.
Old Apr 13, 2012 | 09:43 PM
heres what it looks like on the topside, the piston in the back cylinder, the black line on the wall is where it was reaching top dead center, now look at the piston at tdc right in front of it..
this engine ran and had a slight knocking noise.
Old Apr 14, 2012 | 12:26 AM
Syclone538's Avatar
LS1, from driving through water.
Old Apr 14, 2012 | 04:13 AM
LS6's Avatar
LS6
Scary and informative pictures
Old Apr 14, 2012 | 07:35 AM
hmm. funny i forgot about an ins engine i just did as well. lady said she drove through a big puddle and was coming out the other side when the engine died... i took the plugs out and couldnt rotate the engine over.. (again have to take the plugs out because you cant compress water)so anyways, found a rod broken and bent and jammed up into the balance shaft, obviously it windowed the block out the way out...
Old Apr 14, 2012 | 07:55 AM
sherm6998's Avatar
I bet she'll love the news!
OP: time for a tear down of that motor.
Old Apr 15, 2012 | 04:18 PM
RezinTexas's Avatar
Originally Posted by i_need_land
c350 awd?
Old Apr 16, 2012 | 07:11 AM
0verkill's Avatar
I pulled the spark plugs and the #6 cylinder won't come out. Maybe something hit it and it's bent? All of the plugs were wet with water and oil.
