What chemical to clean deck for Head install?
Old Apr 15, 2012 | 02:29 PM
badazz81z28's Avatar
Default What chemical to clean deck for Head install?
Lucky for me my engine had the MLS gasket so nothing really to scrape off. To clean it tho...what should I use to make it squeeky clean for proper gasket sealing?
Old Apr 15, 2012 | 05:22 PM
Darkman's Avatar
I use a chemical named "Peso" sold at paint stores. It leaves no residue.
Old Apr 15, 2012 | 05:25 PM
dodson55's Avatar
i use a razor blade to scrap it then brake cleaner to spray it off then dry everything with shop air
Old Apr 16, 2012 | 05:34 AM
redtail2426's Avatar
wd-40 works really well with a non-abrasive pad
Old Apr 16, 2012 | 04:35 PM
conv55's Avatar
I used automatic trans fluid with mild scuff pad and worked great, be careful the aluminum is soft in that area.
Old Apr 16, 2012 | 04:41 PM
BrntWS6's Avatar
3m sanding disks from autozone with air tools. You'll have both sides clean in 10 minutes. Just cover sensitive areas up real well.
Old Apr 16, 2012 | 07:39 PM
rickyzZ28's Avatar
I have never used a sanding disk on any aluminum block as I was always under the impression that they take a little material off with them, which is not what you are trying to do. I always use a gasket scrapper with light pressure and then a product called Pre-Clean which is a chemical that leaves no residue as its real purpose it to make sure metal surfaces are clean before you paint. If there is anything left I will use a flat blade razor with very, very light pressure.
Old Apr 16, 2012 | 09:12 PM
BrntWS6's Avatar
I think your supposed to use the yellow 3m roloc disks, their safe for aluminum. I personally wouldn't put a razor on the block, way too easy to gouge it and end up with a gasket leak.
Old Apr 17, 2012 | 12:05 AM
hcb1700's Avatar
I just use a razor blade, and some break cleaner then wait a bit, and give it another pass with the blade. I just can't trust any sanding disk on such an important area, especially when dealing with aluminum.
