confused about which O2 sensors
the AFS123 say they are pre-cats & the AFS98 say they are post cats.
i don't have cats so i only need the 2 pre-cats. i've been told they're the same sensor just the wires are different lengths.
these are going in an 02 camaro LS1 that i swapped into my truck.
can anyone enlighten my on the differences or tell me which ones to run?
SENSOR ASM,HTD OXY
Part Number: AFS123
Product Notes:
Heated Oxygen Sensor (Position 2)
Pre converter ; Right hand ; SS, Z28
Per Vehicle: 1; Years: 2001-2002
SENSOR ASM,HTD OXY
Part Number: AFS98
Product Notes:
Heated Oxygen Sensor (Position 3)
Heated Oxygen Sensor (Position 1)
the 123 says pre converter, rh & nothing for lh or position 4
the 98's don't say pre or post converter.
guess i need to know which sensor is which position.
I just bought new GM parts for my 00 Vette and they are made by NTK.
The planar style heat up quicker and use less heater current to run.
There is excellent info from Bosch, NGK etc on line if you search for Ogygen Sensor Design.
As far as I know, the fronts and rears on our cars are identical except for the wire length and connector style. I have measured them for heater current draw and they are identical.
However, the Corvette crowd will continually say to use the rears in the front when adding headers because they heat up faster and are more accurate without having an ounce of proof to back that up.
Ron
Ron,
some of the earlier Vettes had a flat 4 wire plug in the front and a square plug in the rears, so they couldn't swap those. So like you said, not an ounce of proof to that.
i'll probably just buy another set of AFS123 sensors & go from there.
Did I mention that they were $32 bucks each on Amazon.com?
