Cleaning assenbled heads
Old Mar 26, 2004 | 01:29 PM
1madss's Avatar
Default Cleaning assenbled heads
While I have my heads off changing the gaskets, what's the best way to clean the heads. It looks pretty easy to get the intake runners cleaned up with a toothbrush and brake cleaner, but I would like to try and clean up the backs of the intake valves and the CCs themselves. The exhaust runners don't look bad, just a little carbon.
Any suggestions?
Also, anybody know where to pick up a machinist straight edge to check the block and heads for warpage?
Old Mar 27, 2004 | 12:44 AM
Richard@WCCH's Avatar
It's impressive at how clean combution chambers, ports and pistons stay with unleaded fuels.
If your not going to take the heads apart, I wouldn't recommend scrubbing and washing the ports and chambers too much. The carbon deposits and brake cleaner can work their way into the valve guides and cause havoc. A wire wheel is usefull for removing the carbon on the valves, but requires the head to be disassembled.
Good luck,
Richard
