what oil weight ?
Old Apr 18, 2012 | 09:58 PM
Big Black SS's Avatar
Default what oil weight ?
I have a 5.3 with a big comp cam ls6 intake ported oil pimp, and I have the famous sewing machine noise....what's the best oil weight that I should use? Not only to quiet the sound a little bit but what's going to keep my engine alive the longest ...I live mesa Arizona and it gets up to 115° here
Old Apr 18, 2012 | 10:00 PM
bestlude's Avatar
I used to run 5w30 sythetic but after my cam swap, my tuner suggested 10w30 for the added protection because of the extra power.. so i run 10w30 now..
Old Apr 18, 2012 | 11:55 PM
trans_am7935's Avatar
i run 5w30, no sewing machine noise here. but i also run Castrol, when i used mobile 1, it was louder
Old Apr 18, 2012 | 11:58 PM
SuperSport01's Avatar
10w40 in that AZ heat will be fine.
Old Apr 19, 2012 | 01:31 AM
baxsom's Avatar
5w30 and 10w30 will behave until the the temp gets below freezing. At 0C 5w30 behaves as a 5 weight. at 100C 5w30 behaves as a 30 weight. For a 10w30 same thing. 10 at 0 degrees C, 30 at 100 degrees C.
Old Apr 19, 2012 | 04:06 AM
vettenuts's Avatar
All 30's are not the same. There is an acceptable viscosity range for 30W at 100 degrees C. Mobil-1 is near the bottom of the range and nearly a 20W oil whereas German Castrol is near the top of the range and nearly a 40W oil. If you really want to look into this, go to the manufacturer's web sites and pull the tech sheets and look at the viscosity at 100 C and use that to help with oil selection.
Old Apr 19, 2012 | 04:10 AM
crainholio's Avatar
Sa da tay! Beat that ho with a belt.
What pushrod length did you measure, and how much preload are you running on your lifters?
