help with piston rings>!!!
Old Apr 20, 2012 | 05:32 PM
kalebm22's Avatar
Restricted User
Default help with piston rings>!!!
i am building a 6.0 and my top ring is skinnier than the second ring. which is 1.5mm. the oil ring is also skinnier than 3mm so my standard rings i bought will not work. i thought it was a stock piston, its standard bore. im so confused and need this truck back on the road. please help me, the block was supposed to be a 2007. the rods and pistons are floating pins if that helps
Old Apr 20, 2012 | 05:53 PM
kalebm22's Avatar
Restricted User
i found on summit a set that im pretty sure i need, they are
1.2mm top
1.5 second
2.5 oiling rinng.
they are 40$ per piston, there is no way im paying that, what are my other options? i need this truck back on the road yesterday.
Old Apr 20, 2012 | 08:27 PM
LS1MCSS's Avatar
Look up rings for an 06 LS2. That's what thickness they are. Rock Auto had stock rings for about $85.
Old Apr 21, 2012 | 12:56 PM
kalebm22's Avatar
Restricted User
you saved my but there, thanks a million! $101 with 2 day shipping.
