Bigger injectors?
Old Apr 25, 2012 | 11:29 AM
T3X_SS's Avatar
Default Bigger injectors?
Im in the process of doing a cam swap. I already purchased 243 heads,MS3 cam, ls7 lifters, TSP 7.400 pushrods, and ls2 timing chain. Im only needing some double valve springs, and rear end gear to complete my setup. I Installed my 3600 precision stall yesterday and i think i should be running good. Only thing i need to find out is if im needing to change my stock injectors
Old Apr 25, 2012 | 12:24 PM
dodson55's Avatar
you will max out you stock ones with your setup been there with a similar setup lol
Old Apr 25, 2012 | 12:38 PM
T3X_SS's Avatar
What did you end up upgrading to? 36lb or 42lb
T3X_SS's Avatar
Walbro fuel pump?
Old Apr 25, 2012 | 01:15 PM
dodson55's Avatar
all motor you pump is still fine i went to a set of red top for which are 36lb at lsx fuel pressure and they were at 85 duty cycle i then went to a set of 42lb and they have plenty of fuel left i recommend going strait to 42 myself
Old Apr 25, 2012 | 02:28 PM
T3X_SS's Avatar
Yea i was looking at a set of green top 42lb injectors, cool thanks bro
Old Apr 25, 2012 | 03:05 PM
thunderstruck507's Avatar
Check out the GM injectors from supercharged Buicks. Cheap and they work great.
https://ls1tech.com/forums/fueling-i...injectors.html
Old Apr 26, 2012 | 10:20 AM
T3X_SS's Avatar
I will search for them, thanks thunderstruck507
Old Apr 26, 2012 | 10:59 AM
99T/AMAN's Avatar
I went to the 42# in my car. Plenty of room for more upgrades
Old Apr 26, 2012 | 06:07 PM
93Z2871805's Avatar
Veteran: Air Force
Last year I bought my Ford Racing 42lb green tops (EV1) for $200 new shipped. Now you can get the newer EV6 style 47lb injectors for $229.
