Questionable Compression Numbers
Old Apr 28, 2012 | 09:41 PM
DropTopBird's Avatar
Default Questionable Compression Numbers
I am in the middle of doing a plug swap so I thought I would check the compression while they are out. History of the car: 2000 auto with 125k on the clock and stock internals. Uses no oil between changes save for the slight oil leak I am chasing down. Mileage has been dropping as of late to the point where its ~17. All numbers are dry with all plugs out and car cold. I think #8 might be lower than the others because I couldn't the the connector 100% tight in the hole. I heard a slight hiss when testing that one which is why I think the number was affected.
1- 135psi
2- 130psi
3- 150psi
4- 140psi
5- 135psi
6- 145psi
7- 135psi
8- 125psi
All I could find about cylinder PSI is that the minimum pressure is 100psi. Ive seen other people post numbers in the 180-220psi range, but most of them were not on stock components (eg no heads and cam). Should I be worried about these numbers? Thanks for the help.
Btw here is a pic of the plugs laid out in the order of the cylinders. I think they look alright for 40k, but thought I would post them up to see what others thought.
Old Apr 28, 2012 | 10:21 PM
BOXCHEV's Avatar
No thread jack
But was just wondering about this. Will help me out when I go purchase a new motor.
Old Apr 28, 2012 | 10:35 PM
3rdCoastPowerSports's Avatar
did you do the test with a hot motor? Did you do the test at WOT? after you run the dry compression test, run a wet compression test and compare your two sets of numbers. That will tell you a lot about the condition of the rings. you said you don't have an aftermarket cam is that correct?
Old Apr 28, 2012 | 10:50 PM
Motor was cold, throttle was open, all stock internal parts. I am going to run a wet test, but thought I would post up these numbers first.
Old Apr 29, 2012 | 02:32 PM
Bump for any more thoughts on these numbers. I will have wet numbers as soon as I get the valley cover swap done.
Old Jul 17, 2012 | 10:59 AM
HRHohio's Avatar
Any update?
Interested too.
