228R Cam and Emissions
IMO, I wouldn't run a 228r with a wide 116lsa, Id go with a smaller cam first!
Since you're running the stock manifolds I go with a cam with more exhaust duration, like a 222/226 114lsa (-4*), or a 220/224 113lsa(-4*), a 220/228 114lsa (-4*) .
Or, any of the other cam I already recommended to you.
I had a 228R in my T/A and it wouldnt pass NC inspection. I was even told a 224R would be hard pressed to pass without perfect tuning with a slight bit of luck as well.
Take $50 with you when you go to get tested and just kinda hint around for someone to "overlook" a few things, thats what I did
Through an unlocked, stalled auto, and 3.73s, I made 350/352 on a dynapack dyno.
Gears?
