ported 241 vs 243's
Old 06-05-2012, 07:24 PM
beach cruiser's Avatar
Touche' Yeah, I'm lazy I guess, thought this would be something cookie cutter and someone could get me in the ball park...
Old 06-13-2012, 09:17 AM
Ok, so I picked up my head from the shop, they milled them .009 to get it true. Bolted it on the motor with no head gasket and set up the valve train for 1 cylinder to check clearance. With no Head gasket there is 3/32 clearance on the exhaust side (Intake has more) wich is .09375. Based on that should I mill them any more or leave well enough alone? Also what Head Gasket should I go with? Any Recomendations? Thanks for the help.
Old 01-19-2017, 11:19 AM
jaybuller's Avatar
how did your piston not hit your quench pad when bolting on without a gasket?
Old 01-24-2017, 02:23 PM
fsvaasam's Avatar
Also, you might find this a good read!
http://www.c5registry.com/documents/ls6/page3.htm
Its a good read but i really dont get this one picture. . . . .
If you compare those cutoffs in this picture you can see the floor of the runners are cut differently comparing shades of the cut and shape of waterpocket too. What is really purpose of this picture? You cant see this much difference if they are cut evenly or what do you guys think?
Just want to say again if you are aiming for street these LS1 heads are still badass stuff when ported
Old 01-24-2017, 05:56 PM
wannafbody's Avatar
The 241 doesn't have a smooth short turn radius. The 243 has a rounded short turn radius which should allow the air to turn smoother.
Old 01-25-2017, 09:12 AM
fsvaasam's Avatar
Sure there is difference between 241 and 243 but this picture is wrong to make real comparison.
Quick Reply: ported 241 vs 243's
