Found these in oil drain magnet???
"GM Engineering looks at roller tips on the rockers as poor engineering. 1. You only use a small part of the roller. The rest is heavy and is extra weight on the valve train. 2. As a roller tip gets some miles on it, the roller axle starts to wear an egg shaped hole in the roller and it takes a set. IOW, the roller starts to slide back and forth over the valve tip instead of rolling. This contributes to valve guide wear. When roller tips are new, they work great but they suck when they get old.
The stock rocker tip has a 0.62" radius and it both slides and rolls across the valve tip. GM has an optimization program that optimizes the geometry so that slide is minimized and roll is maximized. It says a lot about the LS engine when you realize the valve train is net build. (non-adjustable) With all those components, there is no adjustment. You bolt everything down and you're there. Not so with the old SB. 20 years ago, you would have been called crazy to try building a net-build valve train. It couldn't be done without hand selecting matched components. The machines used to manufacture the LS parts are new and work so much better than the old SB machines."
Thanks again to all that helped me out on this one. It is very much appreciated. T
I would not pay $40 for a install tool. all you need it what they should be including in the kit.
with a small arbor press I could install a complete kit in less than 1 hour.
Tim
Just thought I would post this for anyone else that has this issue. I can see if I can post the trunion needle bearings and the lifter bearings to show the difference which may help someone else identify them by size etc.. I thought taking the pic with the Domino as a size reference was sufficient but have to think there is a difference I can show with a tape measure or side by side etc.
Still appreciate all the help and still doing the trunion bearings, just not good new since it hurts financially although it is a darn good thing to get fixed and a great time to do it otherwise.
So my hope is that I don't have to change the cam, though if I do and the money is even possible as well as the time he will allow me to take up a bay here, I could fix it and add some power. Otherwise I would just like others that have found these to consider the alternative and/or know about the difference in the way the bearings look or are sized. I sure had no idea which is why I made this post. I ran it by one of the LS1's original GM design engineers and he did not tell me I was wrong about the diagnosis so I assume the answer was the most common but perhaps it could let someone know there is another issue possible also.
In my opinion I think those trunion bearings should be upgraded anyway since it seems enough people have issues and the kit is cheap and relatively easy. If it is the lifter bearings then you will have to have done the same assembly already so you are not wasting time or money by doing the trunion grade but if you get there and there are no missing needle bearings this is probably it, so be prepared. If the cam is damaged then perhaps it might be a good time to install that cam or other valve train parts you were thinking about, or intake etc. as long as they are off. Just trying to share my misery to help someone else out if possible. I do appreciate these threads and everyones helping me with my motor issues though. It is a great forum to have.
