will these valve springs work with this cam?
Hey guys, building a turbo lq4, The cam I have is a TFS 228/230 .588/.588 112
, using stock rockers and comp pushrods. The springs I have are:
Spring Specs:
1.265" OD
.880" ID
130 Lbs @ 1.790" -Valve Closed, Spring Installed Height
355 Lbs @ .595" lift
Rate# 356
Average Coil Bind @ 1.145"
Maximum allowable lift- .595"
will these work with the cam? Also should I get the Trunion upgrade?
Spring Specs:
1.265" OD
.880" ID
Rate# 356
Spring Specs:
1.265" OD
.880" ID
Rate# 356
Spring Specs:
1.265" OD
.880" ID
Rate# 356
.645" - .588" (cam lift) = .057" (tolerance)
.057" - .050" (recommended tolerance) = .007" (wiggle room on installed spring height)
1.790" - .007" = 1.783" (minumum installed spring height)
So you want and installed spring height between 1.783" to 1.790".
You should be fine.
I don't think that it is worth it. Just run the springs that you listed. Just make sure that you check your installed spring height, and get it as close to 1.790 as you can. The closer to 1.783 you get the more stress you put on the valve train. If you go over the 1.790 installed height you won't have your 130lbs of closing pressure when the valve is closed.
Picking a spring with the correct spring rate is far more important to obtain correct opened & closed valve force than hitting the installed height dead nuts.
