What cam should i get
You should stop giving advice. You do not need a lot of compression to run tens. Also, the trex is far from lazy. The TRex is one of the strongest drag racing cams ever designed for a 346. Just because its not ground on EPS lobes doesn't mean its lazy. Seriously, people needs to stop with this "EPS or go home " bullshit.
I agree
Look at the cam only fast list
It used to be all trex and an ms4 and a vindicator
Everyone knows eps makes awesome cams, but a trex is proven to be one of the best performing cams at the strip, why would you steer someone away from it
TREX is on Compcam XER lobes with a variance rate of 49. These ramps are faster than EPS ramps. So "Lazy" it is definitely not. Quite the contrary, it is "violent".
Flycut pistons and milled heads compliment Trex very nicely.
Another similar grind is the "AZPS-03" from Ed Curtis.
Intake Exhaust
Valve Adjustment: .000” .000”
Lobe Lift: .365” .362”
Gross Valve Lift 1.70 Ratio: .621” .615”
Duration @ .050” Tappet Lift: 242* 248*
Lobe Separation: LSA 111*
Recommended Intake Centerline: ICL 109*
Specs at 109 Degree Intake Centerline:
Valve Timing at Open Close
.050” Tappet Lift: Intake: 12* BTDC 50* ABDC
Exhaust:57* BBDC 11 ATDC
Intake Exhaust
