Need Help *update*
Old May 13, 2012 | 06:10 PM
work in progress's Avatar
Default Need Help *update*
I replaced a broken spring, put everything back together and it runs bad. Runs fine under normal driving, but bring up rpms under load and it backfires and runs horrible. I think I may have a collapsed lifter. Any input would be greatly appreciated!
UPDATE- Runs great in open loop. I changed the map sensor thinking that was the problem initially. It seems to run better with the MAF unplugged in closed loop, but not much better.
Old May 13, 2012 | 08:00 PM
Burken01's Avatar
Take the heads off to see what damage is done.
That's the only way to really know..
Old May 13, 2012 | 08:07 PM
crainholio's Avatar
Before you pull the heads, run a compression test on the cylinder w/ the failed spring and a few others for comparison. Should be within 10% of each other.
Disconnect the fuel pump, and hold the gas pedal at WOT during cranking.
Report back w/ findings...bad compression points to a damaged valve and/or piston, good compression points elsewhere.
Old May 13, 2012 | 08:08 PM
crainholio's Avatar
PS: could be as simple as a damaged plug wire when you removed it...
Old May 14, 2012 | 12:09 PM
update in original post
